how to open img file on polaroid
Your post leaves alot of q
-Why would you d/l a firmware?
-Why would you try to open a ''firmware img' ?
You use a 'img' file to flash a Rom/firmware to a device
Depending on H/w there are various tools that can be used to flash..
So.. what kind/type/model to you have ?
Please provide more info..
Cheers
Cheers
so i had to make a split second decision this morning, the store i work at had the Polaroid android tab for 80$, they only had 20 of them with 300+ people waiting outside, so i hid one and bought it later. Now, is there a way to root it and flash...
'm collecting data..
Looks.. like you need to 'disable USb' after transfer.. to get Update popup.. (check notifcation bar)
Other way to update.. is to use to the 'tuturial' on the first link.. it seems
Originally posted by mitchell4you View Posthttp://forum.xda-developers.com/show...1362617&page=5
Many thanks for the links the guide was the one i used originally and didnt work and thats why i was stuck but there is some great info on the otherlink that i will study well !!!! before trying anything. If i have any sucess or tips of course i will post.
DO NOT-I REPEAT-DO NOT FLASH ANY OF THE POLAROID ROMS HERE OR EVEN ON THE SOUTHERN TELECOM SITE TO YOUR TABLET!!! these are not the correct ROMs for your tablet. the name Polaroid is fragmented. you have a european tablet, and as such we don't even know what type of hardware is in it!Originally posted by koosje View PostMany thanks for the links the guide was the one i used originally and didnt work and thats why i was stuck but there is some great info on the otherlink that i will study well !!!! before trying anything. If i have any sucess or tips of course i will post.
Originally posted by elektrik View PostDO NOT-I REPEAT-DO NOT FLASH ANY OF THE POLAROID ROMS HERE OR EVEN ON THE SOUTHERN TELECOM SITE TO YOUR TABLET!!! these are not the correct ROMs for your tablet. the name Polaroid is fragmented. you have a european tablet, and as such we don't even know what type of hardware is in it!
Originally posted by koosje View PostMany thanks for the warning, i decided to leave well alone after reading up o the websites, without opening up the tablet i have no idea which rockchip is inside as documentation specs only says rockchip polaroid????
There are currently 2393 users online. 0 members and 2393 guests.
