pipo m7, problem plugging in micro usb cable
    I have a pipo m7 pro from geekbuying.com and have been pretty disappointed with it. I would like to flash one of rileys mods to see if that improves the terrible performance/lagginess. The problem is no micro usb cable reaches in far enough to make contact. Am I the only one with these issues, I've seen nothing but glowing reviews for this tablet so I'm a bit perplexed. Anyone else with problems plugging in their micro usb cables?
    That is common among ALL Pipo models. You have to use the cable that came with the tablet which is specially designed to reach in the hole.
    I've gotten used to it...since I have so many Pipo tablets laying around. But if you have only one cable, you need to protect it with your life. Always know where it is.
    I'm Randy...and I'm a flashaholic.....hahaha!!!!!
    Randy
    Randy
      Thanks, Randy. That's a weird design decision. I've got the latest riley rom installed now 2.1.1. My tablet seems more usable although I need to reinstall all the apps to see.
      Randy
