Amlogic Next7HD8G (NX007HD8G) Modified Recovery - Stock Rom & Flashable Root
    These files are for the Amlogic Nextbook Next7HD8G (NX007HD8G).
    Here is what you get:
    Modified Stock 3e Recovery:
    This is the stock recovery, dumped from the device, unpacked, modified to use Google Test Keys instead of Private Nextbook Keys and then repackaged for your enjoyment.
    Unzip and place the uImage_recovery file on your external SD Card. Reboot to recovery by holding Volume and Power. You won't notice any visual changes, but you can attempt to flash any .zip signed with Google Test Keys.
    Your mileage may vary. If something won't flash there is a compatibility problem between the updater-binary or updater-script and our kernel/recovery.
    Download
    : (Link removed - Obsolete)
    Stock Rom:
    This is a close as I could get to a flashable stock rom. It is NOT necessary to flash this to get root. If you only want root, just flash the root package below.
    This contains a stock bootloader.img, boot.img, uImage_recovery, logo.img, and aml_logo.img dumped from the device. The system partition was also dumped from the device. I believe all of the Nextbook bloatware is here, with nothing added and NO ROOT. Everything has been packaged into an update.zip and signed with Google Test Keys. This WILL reformat System, Data and Cache. Backup any critical data before flashing.
    Place the update.zip on external SD Card and flash using the modified recovery above.
    Download
    : http://www.freak-tab.de/ShaunMT/Next7HD8G/Next7HD8G_SMT_Stock_Rom_081213-signed.zip
    Root Package:
    This is a flashable .zip that installs the su binary and has been signed with Google Test Keys.
    Put it on your external SD Card and flash it using the modified recovery above. Then install your preference of Superuser.apk or SuperSu.apk from the Google Play store or elsewhere.
    Download
    : http://www.freak-tab.de/ShaunMT/Kyser_Root-signed.zip
    ROM Version History:
    11-11-13 (Current)
    • First Release (Stock ROM using dump of 08-12-13 system build date)
    Feedback Thread: http://www.freaktab.com/showthread.php?8078-Amlogic-Next7HD8G-%28NX007HD8G%29-Modified-Recovery-Stock-Rom-amp-Flashable-Root&p=111796#post111796
    Thanks again to Finless Bob for hosting these files, and thanks to the Freaktab community for inspiring me to work on the Amlogic Nextbook series!
    ShaunMT
    Last edited by shaunmt; 19 August 2014, 00:57. Reason: Removed link to modified recovery.
    Freaktab Rom Developer
