Can my M9Pro boot into straight into recovery, rather than reboot?
    Just managed to root and install CWM Recovery on my M9Pro. The next step is learning how to boot into recovery, rather than use Arctools to reboot into recovery.
    It would be good to know should I encounter any problems that stop my system booting properly.
    In our App Developer's Kitchen section there is a Reboot App by Petrus. If you are rooted it has a menu of reboot options.
    Randy
    Randy
      Randy
      Yes, I am aware of that, but I am looking for a way to boot into recovery, not reboot into recovery.
        The recovery boot process is controlled by misc.img.
        The misc.img in my ROM kit is set to boot to recovery on first boot, but the system changes it after first boot to reboot to boot.img after that.
        If you want to boot to recovery, just flash misc.img from the flash tool.
        Otherwise, I'm not sure why you want the tablet to just boot to recovery each time.
        Randy
          Of course I don't want to boot into recovery everytime, just have the option to. On other devices this is done using a button press combination.
            OK, gottcha!!!!!
            I'm not aware of a way to do it on the M9 Pro.
            Randy
