New Official FirmWare MK802IV (131111):S/N from 201305****to 201306**** old wifi
    Download: http://www.rikomagic.com/en/download/download_22_1.html
    1.Fixed some flymouses and keyboards plugged in, prompts the "Format" problem.
    2.Fixed some audio bugs.
    3.Fixed QQ,Skype video stutter problem.
    4.Removed force horizontal screen display mode,added rotation button in status bar and switch on/off
    option in settings of screen.
    5.Optimized online streaming video playback.
    6.Optimized blu-ray video playback.
    8.Fixed 1080p UI display problems.But note:there might be some third party application layout problems.
    9.Added mobile control QR Code on the main screen.
    Neomode can you make a new version with this rom for the old mk802iv.
      First Antuntu Benchmark test out of the box is 15846.
      I now see that i have a choice menu under the sound output devices between Rockchip HDMI and Rockchip hdmi passthrough.
      DTS and Dolby works with standard video player if rockchip hdmi passtrouhg is set but not yet with xbmc 13.
      Didnt test it with external player.
        +1 with 1080p kernel if possible.
          Stream Direct TV HD (1440x1080) with VU+ Player and MX Player : OK
            Right now I'm running the stock "201307**** till now" firmware and it works great very stable ... Netflix .. Plex ... Dishnetwork HD all working great!
              I've installed this firmware and there is a nice option : Audio HDMI passthrough ...
              With this option I can play movies with DTS & others .
              BUT ... it is slower than with NEOTV 1.5 ! (framerate issue)
              So it would be nice to have the HDMI passthrough on the NEOTV Rom !
              Edit : Or maybe it is possible to fix the Frame skip issue directly on this stock ROM ? Someone knows how to do that ?
                i can not install it?
                i am trying to install this version to my stick but it is not working, reboots on black screen?
                what should i do?
                  Are you sure that you don't have the stick with the new wifi ?
                    i used an other power suply and it works
                    my trouble now is it is not working xbmc smooth but other things i have tested is better now
                    my favourite game is working in this version
                    heroes of order and chaos
                    if someone can improove our stick using this firmware version i will enjoy!
                      As Sam321 told me the problem should come from RKM underclock the processor.
                      It is only running at 1416Mhz.
                      It would be great to have the same firmware running at 1.7/1.8 Ghz, and also to overclock the RAM.
                        RKM won't do that without a reason. @ 1.7 Ghz or more the device will probably suffer from lock-ups due tot overheating, unless modified with a bigger heatsink and/or active cooling.
                        Freakbox V1 F/W 1.0.6
                        Asus Zenfone 2 ZE551ML Stock (rooted)
                        Samsung Galaxy Tab 3 7.0 Nolekat 2.2 custom ROM
                        Asus TF300T Cyanogenmod 11 Snapshot M12
                        Archos 35 Home Connect Stock 2.3.4
                          How can i overclock it? I have already two fans at each side
                            one thing to look out for is even if you do get it overclocked ... and the heat isnt an issue ... watch out for memory fails .....this is what was happening to my system at 1.8 ghz ... it would work great for a while then randomly and slowly I'd loose my nand flash memory
                              I dont understand what to do to it work right
                              What you did?
