Just odd nothing happens. Other devices pop up, just not this one.
PC not detecting Tronsmart CX-919?
I have a windows 7 PC and was going to root my CX-919. According to the instructions, (after USB debugging has been turned on) that when I plug the CX-919 into the PC that my PC should detect a new device has been plugged in and then want to install some drivers. My PC does nothing. So, do I also have to have the AC plugged in as well as the USB? Do I have to hit the FN button on the side of the CX-919?
Just odd nothing happens. Other devices pop up, just not this one.Tags: None
You should press the Fn button first, and then connect your CX-919 with your PC. use the OTG port in CX-919.
try it again.
EricLooking for developers
Originally posted by moviecouple View PostDoes it also need to have the power plugged in too?Looking for developers
Originally posted by britoso View PostMy CX919 is only detected when I hold the "fn" button while connecting the usb port ("marked "USB" and not "DC").
Use the original cable and atleast 5 others, just to be sure its not the cable.
You need a legacy pc with windows xp
I find that none of my pc's (laptops or desktops) running (win 7 or 8) respond well when it comes to flashing with these tools. My POS jurassic laptop running xp is a sure thing. Most of my fail flashes started while using windows 8.
Start with proper driver installation and I can tell you that this is where windows 7 & 8 give you the most problems. You can make it work with windows 8 & 3.0 usb ports because all usb ports are legacy compatible. But why try to complicate things more with basic setup like drivers installation???
There are currently 2612 users online. 1 members and 2611 guests.
