New stock firmware for cx-919 tv stick
Looking for developers
http://freaktab.com/forum/advertiser...91j-smartphoneTags: None
Originally posted by geekbuying View Post
But, does anyone have installed and tested yet?
Any NEW Functions or Fixes?Last edited by ulises1954; 13 November 2013, 01:45.
Originally posted by freakn View PostThanks for sharing. WIll give it a try :-)
Dumbs up for Rockship as well
No lets wait for Android 4.4 to arrive
My cx-919 is on his way to me from geekbuying and I allso willbe a member off the cx-919 community soon.(my pipo m8hd is on holt by customs at this time ....will cost me extraFreakbox V1 firmware 1.0.4
Pipo M8HD, Rileyrom 1.9 KitKat
CX919, Finless ROM 2.0 - KitKat 4.4.2 for CX-919 - BETA
Junk rom
This Rom is just as bad as the last stock rom. The clock speed is 1.81ghz on this stock rom. It doesn't spoof a specific device so Google Play won't let you install a lot of apps (ie MLB, Weather.com). You might as well be using Finless 1.6b. I use Finless 1.6b default installation settings with this kernel: http://www.freaktab.com/showthread.p...007B-or-cx-919Tronsmart R28 PRO with wasser-2.0.7-beelink-r89-rk3288 ROM and MX Player
I will work on a ROM for you guys using this as a base.
It does fix a few things so might be worth it.
FYI not counting the X7 the CX-919 is still my best "stick". I use it all the time.
Originally posted by Finless View PostI will work on a ROM for you guys using this as a base.
Is there anything you can do in your next rom to fix the pointer registering clicks in some games,eg temple run,subway surfers.im surprised the makers of the sticks haven't fixed this yet droidmote is a work around but I have no android phone so that's out for me,,can you work your magic & fix this for goodPlease consider making a Donation to freakTab
Thanks Bob for letting us know that you will work on a ROM using this New Stock Firmware for the CX-919!
BTW, you had mentioned that there are some fixes, and that might be worth it, but could you please tell us what NEW Functions or Fixes does this New Firmware have?Last edited by ulises1954; 15 November 2013, 18:14.
Re: New stock firmware for cx-919 tv stick
Originally posted by bora2004 View Posthello finless, I bought cx-919 to watch 1080p dts mkv files from my nas share. I can not watch it properly. How can I watch 1080p mkv files by cx-919 ? Please advise if there are some tricks.
Then again, all we know is that it doesn't work for you. Does work for me however.
Sent from my Galaxy Nexus using Tapatalk
Originally posted by JugsteR View PostAre we to guess how it connects to the nas? WiFi has a limit for how high your bit rate can be. Using an Ethernet adapter ups that limit and may solve your problem.
Originally posted by bora2004 View Postthanks for your support. I am using usb ethernet adapter for network connection. Are there another tricks for my problem ? best regards.
http://www.vatanbilgisayar.com/bagla...1600#allImages
Originally posted by JugsteR View PostWhat is the performance of the adapter and what bit rate are the movies that fail?
what are you using for adapter ?
Finally got a chance to look at this new ROM.
It does not appear this is that new! Kernel date is 9/26 and build is also late 9/26?
Kernel has frame skipping too.
I will still do a ROM based off this but I would think there would be a newer ROM than this from CX since 9/26?
There are currently 2676 users online. 0 members and 2676 guests.
