Issue #1... The Google Play Store (app) gives me a "No Connection" and won't connect at all anymore. Worked fine for a few days and now nothing. I still have perfect wifi connection because I am able to use the Stock and Chrome Browsers & weather works too. Just the Store App doesn't work anymore.
I have even reset back to factory and it works for a day or so and then again goes back to "no connection".
Issue #2... When I am using the Stock or Chrome browsers I keep getting security certificate pop ups. They pop up so much that it is nearly impossible to use them at all.
What is going on. I have not downloaded anything initially other than stuff from the Google Play Store... so it should be a virus or anything like that.
Help! Otherwise this thing is going back.
