rikomagic 802iv stock rom via cwm
if you have a Rikomagic stock rom you should have root this is a big help in this case
since you can't connect to a pc I would suggest a app called ArcTools
here is video instructions on how to get it done
after you have istalled it you can the use the Arctool app to reboot to recovery to flash/backup and restore roms etc
alternative you can press reset on power up after you installed CWM to enter it .... if you do that and its no installed you go to default recovery this is ok too! ... just do nothing for around 15 min and it will boot normal
There are currently 2559 users online. 2 members and 2557 guests.
