Whats your antutu score
    Hi eveyone im just curious whats your antutu score with a 1080p rom on the mk802iv.
    I just got 19305 by modding the stock kernel with phjanderson tool. Some pics:
    I'll try to fix a few things on the firmware that i'm testing and ill upload it so you can try what score will hit your device.
    Cheers
    Sent from my GT-S7562 using Tapatalk
    FIRMWARE & HARDWARE COMPATIBILITY LIST FOR ANDROID TV STICKS
    https://docs.google.com/spreadsheet/pub?key=0ApGXribKk_8gdEc3YnlmOHlfRlRQVUxFbkJ3Zzg3U EE&output=html
    My Plexi MK802IV mod
    http://www.freaktab.com/showthread.p...xi-MK802IV-mod
    Here's my best score so far with my MK822 with the latest stock CX-919 firmware
      Hi, any news neoal about your project?
        Re: Whats your antutu score
        Eventhough the score is good on 1080p, the ui and apps are very laggy and slow so I think is difficult to have a rom for this resolution
        Sent from my GT-I9500 using Tapatalk
          it seems our cpu chips are decent but our graphic chips lack the memory for higher resolutions
            This is what one of the highest scores I got on 720p, the best was 22*** something but I don't have a screenshot
              [ATTACH=CONFIG]4073[/ATTACH]
              [ATTACH=CONFIG]4074[/ATTACH]
              Awesome! What setup (kernel, rom...)?
                And what version of mk802iv? the new wireless cheapset or the old one?
                by the way this is the best score ive seen with that stick, mine goes to 19400 with overclocked cpu and ram to 1800 and 1500!!
                NICE
                  wow after seing a score over 2000 makes me wonder if i shouldn't just run 780p allways
                    Thanks, I must say that my mk802iv had at least 3 casemods already (you can check the first two here http://www.freaktab.com/showthread.p...e-quot-Casemod), currently I'm only using a "big" aluminum heat sink for cooling the cpu/gpu and both ram chips and a case very similar to the one I had before (I'll post some pictures) but without the fans and the power switch, the rom I'm using is NEO TV CR 1.0 Neomode Custom Rom 4.2.2 (works better for me than 1.5 version) and the 1.9ghz / 1500mhz ram Extreme Overclocked kernel (with the gpu fix, but I get a better score on antutu using the "old" kernel without the gpu fix) from Sam.
                    NICE
                    It's the one with the old wireless chipset.
                    I use my mk802iv on a 47" full hd LG led tv and can't tell much difference between 1080p and 720p kernels, so I kept the one with better performance
                      Really high score for the mk802iv. Highest score I had in 720p was 20100 with old antutu. How much scores your stick gpu, cause I can't see that???
                        Here, with a slightly better score
ID:	431310Click image for larger version
ID:	431311Click image for larger version
ID:	431312Click image for larger version
ID:	431313Click image for larger version
                          way cool
                            [ATTACH=CONFIG]4086[/ATTACH][ATTACH=CONFIG]4087[/ATTACH][ATTACH=CONFIG]4088[/ATTACH][ATTACH=CONFIG]4089[/ATTACH][ATTACH=CONFIG]4090[/ATTACH]
                            BrunoNRG you have the old wifi version?
                            We can`t overclock the gpu with the new wifi something stops it! any ideas?
                            Last edited by babnik80; 24 November 2013, 20:08. Reason: Sorry i just saw that you said it in a later post.
                              Yes, my mk802iv has the old /first wifi version
