Thanks in advance guys.
Do you recomend Rikomagic 802IIIs bluetooth?
Is this a good tv stick to own. I need it for XBMC and playing gameloft games. They have a remote apk which you can use an android device to control. Can anyone comment on this? Is it able to perform well? Can we play games like this?
Thanks in advance guys.Tags: None
Go for a Quad core...
Originally posted by yrtrnc View PostIs this a good tv stick to own. I need it for XBMC and playing gameloft games. They have a remote apk which you can use an android device to control. Can anyone comment on this? Is it able to perform well? Can we play games like this?
I own an MK802IIIs, it will run XBMC but only plays SD and Some 720 good, the device is simply not powerfull enough, go for a quad core device, and if you are the least unsure on your wifi, go for a device with build in ethernet. I now use the OUYA, and i have a K-R42 in the mail, have look at them, and also Minix X7.
Happy hunting.
Originally posted by Moszad View PostI own an MK802IIIs, it will run XBMC but only plays SD and Some 720 good, the device is simply not powerfull enough, go for a quad core device, and if you are the least unsure on your wifi, go for a device with build in ethernet. I now use the OUYA, and i have a K-R42 in the mail, have look at them, and also Minix X7.
Happy hunting.
Thanks Buddy.
Also maybe your problems with XBMC are due to no HW acceleration. Since the device has a RK3066 ( quad core mali) it shoud be more than capable to run 1080 video right? Maybe if HW acceleration was supported then it would work ok.
How do you guys think it compares with the MK808B?
There are currently 2869 users online. 0 members and 2869 guests.
