How I Made the Stock Rom (PMID701C)
    First off I'd like to point out the following, in notpod's dump, he had two things switched, boot.img was root.img and root.img was boot.img. So boot.img is the only FAT image out of all of the nand dumps. I have uploaded a fixed rom dump below with the correct file names.
    To cook this rom, I found this allwinner a10 kitchen used to cook up android roms into a flashable Live Suite img. The tutorial is here. That tutorial is for snowbreeze, but the kitchen I found has the same setup. To start off, I downloaded the kitchen and extracted it. I then extracted the files from boot.img to _bootfs (using MagicISO) and inside the linux folder was a file named bImage which I copied along with root.img, system.img, and recovery.img to the _input folder. To get the files needed for configuration, I had to place the Onda Gingerbread rom in the root of the kitchen and run extract_image.bat. After that finished, I then ran create_image.bat. The end result was a stock rom which I then flashed to my tablet.
    Inside _input:[bImage, root.img, recovery.img, system.img]
    Inside _bootfs:[contents of boot.img]
    ROM DUMP
    A10 KITCHEN
    STOCK ROM
    I am currently working on a new rom and should have it finished by Sunday. (Gingerbread 2.3.7)
    Shawn
    Shawn, you still working on this?
      Yeah, needs a bit more work.
      Shawn
        OK, still not getting it
        Even downloading all your sources (kitchen, rom dumps, etc), setting things up as you did, etc when I go to flash it goes about 20% then the counter quickly falls back to 0 and fails. I can still flash any other working rom I can find, just cant seem to make the kitchen work.
        I need this to try and make a ROM that will see the second flash IC I installed, but cant seem to even reproduce your work.
        One question when it is cooking the ROM up after you type create_image does it go very fast for you. It takes about 5 minutes to extract the image but it is taking only a minute to build.
        Any thoughts?
          nevermind
          figured it out i think. i had an extra copy of bImage in _bootfs. looks like i can procede onward now.
            Seems like a good place for this kind of info
            I find myself using these alot while working on figuring out the configuration stuff so I figured I would compile and put them here since this seemed like a good place for them
            To pull bootfs from the tablet
            Hi! I haven't really found any kind of guides on how to build a complete AOSP android build from source (kernel and software) for Allwinner A10 tablets like the Ainol Novo 7 Advanced or the Teclast P76Ti. I have a Teclast P76TI (rev4), and the...
            > cd _bootfs
            > adb shell
            $ cd /
            $ mount -o remount,rw -t ext4 /dev/root /
            $ mkdir bootfs
            $ mount -t vfat /dev/block/nanda /bootfs
            (Control-C: exit adb shell)
            > adb pull /bootfs
            To unpack the config.bin in Linux:
            ./script2fex.rb script.bin > script.fex
            ( http://tabletrepublic.com/forum/cort...ripts-410.html )
            After changes repack with:
            ./script script.fex
            and copy back to the bootfs, rename the first copy config0.bin and paste again
            Then boot back into windows to compile.
            Dont forget to make changes in the config files in the _extract folder as needed
            I need to see if I can pull off doing it with just windows, would speed up the process considerably
              ics AOSP and kernel released
              I am guessing only those that really would be interested would look in this thread
                http://forum.xda-developers.com/show...&postcount=121
                This got my attention! Thanks!!
                Jim
                Ainol Novo 7 Elf II Dual Core
                Milestone (Droid) - Chevy SS GB ROM
                Milestone X - Rooted Stock GB ROM
                  Would I be able to use this method and the kitchen to cook ROMs for a Polaroid A/S8? I've been looking all over the place and no one else has made anything except a recovery for it and the stock ROM/OS is just to crappy, no optimizations and there are way too many un-used and pointless partitions using too much of the storage. Lets just say, there are a lot of reasons for switching to a custom ROM.
                    Possibly, depending on whether you can unpack the 'stock' A8 ROM without errors (GuessYet was able to, but I was not). Go for it!
                    https://public.bay.livefilestore.com...ion.png?psid=1
                      That's just it though, I've tried asking what setup he was using as far the right kitchen setup and i haven't heard back yet.
                        Hmm...can't help you on that one....
