XBMC & MX player
XBMC & MX player
i have a CS918 and every version of XBMC stutters, it said i should run MX player before starting XBMC which ive done, ive tried every version of XBMC yet streaming from my NAS in 1080p always results in unwatchable streams. I have it connected to a gigabit network so its not bandwidth and it plays fine through my Pi so i don't know what the problem is. Could someone tell me which version works and what settings i should be using including the ones for MX.
ThanksTags: None
Originally posted by polly69 View Posti have a CS918 and every version of XBMC stutters, it said i should run MX player before starting XBMC which ive done, ive tried every version of XBMC yet streaming from my NAS in 1080p always results in unwatchable streams. I have it connected to a gigabit network so its not bandwidth and it plays fine through my Pi so i don't know what the problem is. Could someone tell me which version works and what settings i should be using including the ones for MX.
apps,if video are not readable, often just clic on H\W then select S\W. Often, in almost of the media players just to switch on software decoder is the way to get a watchable streaming.Bonjour! Je suis de Shawinigan, Québec, Canada
i like the JustXbmc firmwarefor the CS918 , it has the best hardware accelerated video playback for android i have seen. Only videos with very high bitrates and 3D-SBS videos are stuttering, for these files i use the MX player in HW mode. Just press the menu button(c) in Xbmc and select MX player for playback, this works only with local files, not for videos on a NAS. For NAS files use the explorer to select your video and play it direct with MX.
I think, until we have a 100 % hardware accelerated android Xbmc version this is the best way to use Xbmc...
Regards from Germany
GerdCS918 with v1.1.1 justXbmc firmware from lewy20041
Out: HDMI
In: Logitech K400R keyboard, Flirc adapter for XBMC and Logitech Harmony
Gerd
There are currently 2901 users online. 0 members and 2901 guests.
