Imito QX1 XBMC Stutters
    Hello,
    First of all I should apologise for my English, as it's not my first language.
    I'm new here, so I hope I posted this in the right section.
    I recently bought myself a Imito QX1 witch had Finless 1.5 pre-installed.
    I installed XBMC and some addons.
    The XBMC seems to work good, but it stutters a lot especially 720p
    I don't know what i'm doing wrong, and hoped anyone here could help me locate/solve the problems.
    Some info;
    I would like to use it in combination with Wifi--> arround 20-25 mbps.
    It buffers, so I guess its not a speed problem?
    Grtz. Sjors
    Originally posted by sjurres View Post
    Hello,
    Some info;
    Grtz. Sjors
    Hello
    I did have some issues when using XBMC with the Finless 1.5 rom. I have installed Leolas 1.5a rom and a fresh copy of XBMC (official) and used the hub wizard from the Fusion installer. All is running very well. Does have the odd stutter but Leolas, i believe, is looking to try and fix playback stutter issues in his next rom. Also, which kernel are you using?
      Just finissched installing xbmc 13.
      It's better but i think it could be better.
      Was thinging about the leolas rom with the overclocked 720p kenel.
      But i'm not a pro at installing these things.
      Is there somewhere a topic witch makes it easier for me? (Step by step from beginning)
      Thanks!
        Thanks!
        Leolas explains it well on his rom download page...
        http://www.freaktab.com/showthread.p...-5-(30-10-2013)
          I'm trying to get it to work witch CWM but it isn't that easy i gues.
          Can get into recovery mode and go up and down. but can't click on OK to get i apply update from sd card.
          what am i doing wrong.
          Also the scalling i way of but that's not the biggest issue
          BTW when i get that for, witch kernel would u go for?
          I think the most overclocked kernel would give temperature problems?
          gr. sjors
            gr. sjors
            I use a remote keypad and can move up and down and use enter to select. Will more than likely do the same with a standard usb keyboard plugged in. What is the issue with scaling? I am using the kernel just down from the highest overclock and it is running great. I have just re-installed the fusion installer with a fresh version of XBMC 12.2 Frodo and looks like they have updated it again. Running well. If you have any slight temperature problems you could always fit an old pentium or motherboard heatsink to the device on both sides. I attached mine with thermal pads.
