will try that later on. because i compiled this kernel on my arm device i didn't know how to look at for the error (source, mkbootimg or even compiler). by now i added asix support and is doing fine.
Picuntu 4.5 on MK808 & MK808b - SUCCESS!!
Problem with installing Mesa drivers
I followed Hizzle's guide, I managed install mali400_2.1-13_armhf.deb package, but I stuck on next step, which is installing Mesa drivers. I have MK808B, and I was using 3.0.36+ kernel recommended in a guide.
During the install I get this error:
WARNING: The following packages cannot be authenticated!
libgbm1 libxcb-xfixes0 libegl1-mesa libopenvg1-mesa libegl1-mesa-drivers
Install these packages without verification [y/N]? y
Err http://ports.ubuntu.com/ raring/main libgbm1 armhf 9.1.1-0ubuntu3
404 Not Found [IP: 91.189.88.140 80]
Err http://ports.ubuntu.com/ raring/main libxcb-xfixes0 armhf 1.8.1-2ubuntu2
Err http://ports.ubuntu.com/ raring/main libegl1-mesa armhf 9.1.1-0ubuntu3
Err http://ports.ubuntu.com/ raring/main libopenvg1-mesa armhf 9.1.1-0ubuntu3
Err http://ports.ubuntu.com/ raring/main libegl1-mesa-drivers armhf 9.1.1-0ubuntu3
Failed to fetch http://ports.ubuntu.com/pool/main/m/...ntu3_armhf.deb 404 Not Found [IP: 91.189.88.140 80]
Failed to fetch http://ports.ubuntu.com/pool/main/li...ntu2_armhf.deb 404 Not Found [IP: 91.189.88.140 80]
Unable to correct missing packages.
E: Aborting install.
Any ideas what it could be caused by?
Regards
Wolf
@ Wolf
Had same problem with Radxa;
It could be useful for others (that's strange i'm the only that faced this issue!):
since Ubuntu raring has reached EOL and packages removed, i tried to find packages on other sites. I found that when a release is at EOL packages are moved in old-releases.ubuntu.com!So, it's enough you edit the /etc/apt/sources.list file, cancel the previous line and insert the following new lines:
deb http://old-releases.ubuntu.com/ubuntu/ raring main universe restricted multiverse
deb-src http://old-releases.ubuntu.com/ubuntu/ raring main universe restricted multiverse
deb http://old-releases.ubuntu.com/ubuntu/ raring-security main universe restricted multiverse
deb-src http://old-releases.ubuntu.com/ubuntu/ raring-security main universe restricted multiverse
deb http://old-releases.ubuntu.com/ubuntu/ raring-updates main universe restricted multiverse
deb-src http://old-releases.ubuntu.com/ubuntu/ raring-updates main universe restricted multiverse
deb http://old-releases.ubuntu.com/ubuntu/ raring-backports main restricted universe multiverse
deb-src http://old-releases.ubuntu.com/ubuntu/ raring-backports main restricted universe multiverse
deb http://old-releases.ubuntu.com/ubuntu/ raring-proposed main restricted universe multiverse
deb-src http://old-releases.ubuntu.com/ubuntu/ raring-proposed main restricted universe multiverse
then save, close and in terminal sudo apt-get update.
The concept is valid for each release passed in EOL. it's enough to substitute the name of release /etc/apt/sources.list file (in our case it is raring) "
This got me up and running.
Later Cappybob
someone has manage to make wifi working in 3066??
Hello.
Thank'you to share your experience.
For me, on my mk808, picuntu 4,5 was work just unpacking system.img and ready.
It was work with picuntu 0,9 rc2.2 kernel and galland 308.
I was trying copying the modules and firmware... but is'nt so easy i think
Someone can help to make work wifi with picuntu 4,5 in mk808??
Sorry for my english folksmy spanish or french are much better
is your wifi working??
Originally posted by lrp1985 View PostI managed to get running picuntu 4.5 with galland kernel 720p, I follwed all the steps from the mini guide, when I run es2gears I got 150 fps wich is ok, but I downloaded openarena and it seems to me that HW Acceleration is not working the game is too slow, same as SuperTuxIs this ok?
Is your wifi working?
Mine don't work ;(
If yours yes, have you do something more that was explained in the guide?
compiling ...
i will try this.
Starting from Rockchip Linux' source code, along with several tools, we will end up with a recovery.img file. This is used to flash the rec...
we have kernel, modules + firmware then ...
only to copy under linux with the correct permissions and run a comand??
Someone see something better to do? i'm not developper...
edit:
wifi don't work...Last edited by pulso; 21 September 2014, 23:24.
sudo dpkg -i mali400_2.1-13_armhf.deb does not work
Hi, I followed the instructions install picuntu on MK808. I can not install mali400_2.1-13_armhf.deb. File is in the root directory Picuntu. The command sudo dpkg -i mali400_2.1-13_armhf.deb does not work.
dpkg: error processing mali400_2.1-13_armhf.dep (--install):
cannot access archive: No such file or directory
Errors were encountered while processing:
What is wrong?Last edited by pavel323; 08 October 2014, 10:26.
There are currently 2382 users online. 2 members and 2380 guests.
