MK808B Image Backup
    MK808B Image Backup
    I need to program multiple devices with same SW and installing same apps, so is it possible to backup an image from the first one and apply it to the others and save time? if yes, please provide the instructions.
    Thanks,
    HI there
    if you want to program multiple devices,i'd like to suggest you to take a look at this image program:
    Overview for How to Use XImage.Raster in C# .NET Programming Project
    It offers a free trial for image processing.You can have a try.Hope to help you.
      looking for same thing
      I program many mk808b's for friends and family. I do them one at a time and it is a pain in the buttocks. I've got it down to about 25-30 minutes per device that's with testing to ensure XBMC is working properly with the installed addons. Having a image of a completed one and being able to program another with one click would save me countless hours. Is there any program that is free and proving to work? I believe you can do this with the CWM recovery tool but it seemed a little bit over my head or is it not that hard (and using that method requires a micro card correct?) I really need someone to point me in the right direction if there is such a tool. thanks all
