I recently purchased an android box off **** that looks like a K-R42.
Using the original K-R42 firmware on geekbuying dated 20130702 or using the HFW 1.2.0 firmware by lewy20041 the box is stable and works.
However if I use a newer than 1.2.0 HFW firmware, justXBMC or wasser firmware the box becomes unstable, apps crash including xbmc and the box reboots alot.
Anyway I decided to open it and take some photos of the pcb and it looks the same as a K-R42 but with different model info on it. It has on it K-RK3188-V3.1 and there is no date info.
I have taken several photos of the PCB and posted them here https://www.dropbox.com/sh/fhmnbzjqlgxfcah/D1BPS5Tb5T
The strange thing is that I also tried the Minix Neo X7 - Finless 1.7 ROM and although WiFi and Ethernet did not work, which was expected the box was stable like the OEM Firmware.
I plan on trying wasser firmware again after work and adb debug the box to see if there is any more info. Is this the best way to debug kernel issues?
So my question is does anyone have any advise on what I can do to help or fix the stability issue.
Neil
