Since it appears to be a RK3188 Chip with 2 cores disabled or removed, then does that mean I need to use the flash roms for RK3188 chip devices, like the MK802IV ?
When I tried to flash it with the MK802IIIs Rikomagic S8B_1080P_20130902_V1.0.zip file it seemed to work, but the Wireless network would not enable and kept turning off.
I ended up updating back to the Rikomagic USA flash called
http://rikomagicusa.com/downloads/netflix_dual_core.zip which is JB 4.2.2.
How do find out what custom firmware will work with this device?
Also, how do see what kind of Wireless network chip this device is using?
I'm almost tempted to flash with this just to see if it will enable my device to use 4 cores:
Any help/guidance is much appreciated.
