I run a MK808B (Finless 2.1) with a custom XBMC release suitable for external players (= RockVideoPlayer).
All the files I have are mkv format and I don't get any error messages when playing tv shows, however I am not to watch movie files (= Sorry, this video cannot be played.).
Works fine when opening the file with the RockVideoPlayer directly (w/o XBMC).
Lol.... Old or new?
Not that it matters much..
Wololo is great.. that it can use internal (with h/w accl ) and external players on-demand (aka play using)
So, just try another video player
I know.. gibby and veetle.. are sometimes not playable using mx.. but internal or 4k do work
Goodluck
Ps,
I'm using old version.. if you are using 'the new' version.. question.. does nav-x run?
-old version it just crashes xbmc.. im wondering if it solved in the new version
