MK808B stock frequencies and overclocking?
Hi guys, got a MK808B on the way and just want a bit more information about it as what I've ready so far seems somewhat conflicting. what are the stock frequencies of the device CPU/GPU/RAM? what overclocking options are available at the moment? I plan on running 4.2.2 but from what I can see there doesn't seem to be much about kernels/overclocking.Tags: None
Unfortunately, there are no custom kernels for the mk808b. At the moment, the only working way to overclock is to flash a mk808 custom kernel, but you will loose wifi and bluetooth if you do so.
There is a tool that tries to patch binary rk3066 kernels to allow overclocking (see here) but it doesn't seem to work well on the mk808b (there also has been some discussion about this problem in this thread).
The stock frequencies depend on the firmware,
on Android 4.1 it is 1ghz CPU and 400mhz GPU. I am not sure about RAM, but i think it is around 500mhz. On Android 4.2, CPU can clock up to 1,6 ghz (but don't expect a great speed boost from that).
There are currently 1030 users online. 2 members and 1028 guests.
