SPMC
    Originally posted by wackidth View Post
    HBut now the problem is, I can't get DD. I only hear "white noise"
    When I disable passthrough I hear sound, but no DD.
    Is there a fix.
    It seems Koying has implemented a check for a MINIX device. If the device id is spoofed in build.prop, the passthrough hack will not be activated:
    With Wasser's XBMC multichannel passthrough works nicely.
    NVidia Shield TV 2015 16 GB || Stock
    NVidia Shield TV 2017 16 GB || Stock
    Buy me a beer?
      SPMC
      That is correct, but i don't think that wassers version has the specific rockchip stagefright hardware acceleration (but only the basic one). The check is to see if the model is "rk3" based, and if so, when enabled stagefright in hardware acceleration settings, to use the rockchip variant of stagefright. So if there would be no check it will use the basic stagefright (which is not optimized for rockchip devices).
        Also this post is useless:
        Big Thanks! It works like charm! My Q7 Box is rubbish... but SPMC makes it bearable to use... Really - big thanks!
        Kind regards Snuffy
          New version of SPMC is out fixes the 10 min freeze bug
          Folks........Koying has just released a new version of SPMC and it fixes the somewhat famous 10 min freeze bug that users experience in the standard builds of xbmc with highly encoded 1080p rips. This is most common with the demon88 plugin inside of mashup. I just tested several 1080p streams from demon88 and they all worked fine. You can find the new version of SPMC here..............http://spmc.semperpax.com/
          Enjoy,
          Vec
            Hello i am using wasser firmware 1.0.4 and spmc 13.3.
            I have modified the build.prop and did all the changes as shown below to enable passthrough.
            ro.product.model=NEO-X7-216A
            ro.product.brand=minix
            ro.product.name=rk31sdk
            ro.product.device=rk31sdk
            ro.product.board=rk31sdk
            ro.board.platform=rk30xx
            ro.build.product=rk31sdk
            but still is not working. Do i have to change/write something else for minix X7 mini version?
            thanks
              Just a note that the "neo-x" check in SPMC for passthrough is a leftover I forgot to remove.
              Will be fixed in next version.
              The "rk3" for HARDWARE will stay, of course (only way to know whether to enable the hack).
                Thanks for the reply koying. Do you have any idea when the new version will be released?
                thanks
                  Links icefilms
                  Edit.....
                    launcher
                    Koying is There a way to disable having spmc recognised as a launcher? Because with this version the navigation bar will not hide it self on qs2
                      Good one. I noticed this on Minix X7, too, but didn't link it to the fact that it's a launcher.
                      Unfortunately, it's a static setting in the Manifest, so the only way is to create a different, non-launcher, apk.
                      Unless someone, has a link to, e.g., the qs2 android sources so that I can see if a workaround is possible?
                        If I recall correctly I read somewhere about this for an other custom xbmc build with build-in launcher functionality. It is the 1st time that I am facing this on one of my devices. Could you provide a "launcher free" version, or the changes in the manifest/ changed manifest so I can try and compile it myself? That could help determine the problem.O:-)
                          Re: SPMC
                          qs2 was made using MINIX stock rom , we didn't had the sdk so it is a modded ROM from the MINIX x7 neo 007 official firmware.
                          My devices:
                          Gearbest.com)
                            it doesnt work on my mxIII (amlogic s802), everything looks fine but when i try to play a movie it doesnt work, nothing renders to the screen.
                            i am doing something wrong? this version doesnt work with amlogic?
                            thanks in advance.
                              UT2 - Need Info
                              Here's what I have:
                              Ugoos UT2 RK3188 also have a 3188T (I have one of each)
                              Wasser V1.25 JB
                              Will this work with SPMC and give me pass-through? Or do I need to be running a KK ROM?
                              I tried it yesterday on the 3188(no T) with no luck. All I heard was the oscillation noise (motorboat)
                              FLHT = Harley
                              HEMI = 2010 Dodge Challenger SRT
                              Cause I've been asked.
                                v13.3.2
                                Huge props for coming out with this version.
                                Runs super smooth on both my Rikomagic mk802iiis(b) and mk902.
                                I really love that you added....
                                "Do not pause music when going to background"
                                I like to have an alarm set but when the visual part of the alarm kicked in, it would pause the music. Now that doesn't happen.
                                I am really hoping that if the intent is to eventually go back to XBMC/KODI that this feature gets added back.
                                If not then I'm keeping SPMC.
