USB, external HDDs, complications
    Hi all,
    I run an MK808B with a USB hub (3x external HDDs) connected to it.
    Unfortunately on start up the device doesn't recognize these HDDs (mostly only one of three), thus I have to unplug and replug them manually every single time. This way it's missing the point of a smart TV entirely.
    Is there any way around this?
    Input is highly appreciated.
    Well.. a smarttv.. is just a terminal for accessing data.. stored else where (in my opinion)
    --I think.. you might need a 'nas' like device..
    --For your collection..So, you can access data from every/tv(s) terminal in your home
    anyway..
    What 'mount' app(s) have you tried ? (g-marked has many)
    do you have 'root' ?
    You could make/edit/add those HD's to your 'vold.fstab' (there are youtube vids )
    are those HD's external powered? are the NTFS ? Under 3TB ? more info needed
    Goodluck..
      Finless 2.1 (so, yes to root), ES file explorer, 1x 1TB, 2x 500GB (all NTFS), active USB hub.
      Does that help?
