Performans
    Performans
    Hey. I'm new to android and KR-42 too. Lewy's firmware installed. and I am very satisfied.
    However, to enhance the performance of K-42, I need to other applications.
    I may be wrong, but if we can create a swap partition, for example ...
    Are we able to expand NAND flash space.
    or applications are absolutely necessary to have these tools are???
    We also need information on these issues ...
    from google translate my English
    Pardon me: ((
    Hmm.. i think you mean:
    To make the internal nand bigger.. search freaktab for 'vold.fstab'
    this tweak..makes the sd-card the internal/space.. giving more room for app(s) / data
    note..
    Swap space.. is a tweak.. that makes a 'buffer' or ram cache.. it helps 'cached process'
    It usefull when you are a heavy user / many apps / lots of switching between app / on a unit with low on ram
    On a K-r42 with 2gb not realy usefull.. (as ram is quicker then swap + swap is bad for the lifespan of nand/sd )
    There is a app.. called 'swapper 2' thats quite good..
    If you need more speed.. search freaktab for a overclocked kernel or make/create one
    Or use a overclocker app
    Anway.. goodluck
      Try Recovery~~~and I do not know the details!
