Help with CWM installation
    Hi Guys,
    Just flashed the latest stock firmware #66 in my Pipo M9.
    I am now trying to flash the CWM but without success.
    I have done this many times before but this time I just can't go into CWM. Always get the android dummy lying down with the open belly.
    have tried to flash the CWM in x0001000 and x0001400 and none worked.
    As last resort I have installed rom manager from the Google store and when I execute the app its showing CWM na TWRP installed.....
    Can you give me some lights with this?
    Thank a lot
    Another solution
    Try this, was quite easy for me: http://www.freaktab.com/showthread.p...8-3066-devices
      I found the problem
      I was flashing the CWM on x0001400 instead of x00014000.
      I missed a zero.
