Rescue Package RK3188 AP6210 S400 All-in-One
i've installed the drivers on windows 7 64 bit and so on. it shows as rockusb device in the device manager. the flash tool detects the device everything is fine there and i wiped my device just fine.
the problem is when i open the batch tool to flash the device it doesn't recognise the device no matter what i do.
any help would be appreciated.
edit-------------
found the error... it's something in the ini thats if you have that problem look below.
search for
LOGFLAG=TRUE
#SUPPORTLOWUSB=TRUE时,扫描支持full speed usb设备,默认只支持high speed usb设备
SUPPORTLOWUSB=
This you change into:
LOGFLAG=TRUE
SUPPORTLOWUSB=TRUE
FULLSPEEDUSB=TRUE
thanks toroelski for the info.
Guest
Is there any way to add a custom (6GB) parameter to this rom?
I have tried myself, but failed several times.
please look here >>> http://www.freaktab.com/showthread.p...l=1#post133732
i've got 1 rom with wi-fi working, but only one, i tried all @f here. what's wrong ?
There are currently 1827 users online. 3 members and 1824 guests.
