For thse of you that have been searching all over the interwebs for a solution to this problem well here you go
How to root XOLO X1000
***Disclaimer - You accept full responsibility if by using these directions your device explodes, leaves you for another owner, or just decides it doesn't like you anymore. I am not responsible!***
***CREDITS***
I did not create Impactor nor Snappea, I just managed to figure out Impactor works to obtain root on this device and many others
ALL credit for Cydia Impactor tool belongs only to its developer Saurik
Make SURE you have USB DEBUGGING turned on
Next, you will need suitable drivers, there is a way to install drivers elsewhere but a much quicker way is to go to www.Snappea.com and install this program on your PC, it is just a program that allows your phone to better interact with your PC but the bonus is that it can install generic drivers (including that much needed ADB driver) for almost any device! Once snappea is installed simply connect your phone to your PC when Snappea prompts you to.
Finally go here:
Download Impactor and unzip the file, once unzipped simply open the Impactor folder and double click the Impactor Application. This will pop up a box that says Cydia Impactor at top on your screen. You should see a drop down menu that currently says "# drop SuperSU su into /system/xbin/su". Make sure that command is showing in the drop down box and press the start button on the right side.
Once this completes you will just need to download your favorite Superuser or SuperSU app onto your device then update binary and you are rooted!
Good luck!!
