BUt when it's working with my sim card in it's great and very accurate.
Pipo m6 pro in car charging
I bought a charger for my m6 pro but it did not work after looking at it it was only 5v and the m6 has a 9v power input so i have ordered a 9v one and i will see when i get it whether it is of any use. I will post the results after testing. I use google navigation and it lasts for about 3 hours on a 3/4 charged tablet. Not enough to go from Newcastle to London.
BUt when it's working with my sim card in it's great and very accurate.Tags: None
EXT 9v BATTY PACKS FOR PIPO's ???
Originally posted by GPShunter View Post//snip// the m6 has a 9v power input so i have ordered a 9v one and i will see when i get it whether it is of any use. I will post the results after testing.//snip//
Here is what I got: http://www.****.com/itm/390651973766
As an FYI, if you have a jumpstarter for a car that has a lighter plug port on it, as I do, I can also use that huge battery in a pinch, and that's a LOT of juice
Now I'm looking for an external Li-ION batty pack, but I need to be sure it has the proper tip, does anyone know the tip size / type / spec?
EDIT: Just found this on the tip:
http://www.pipomall.com/m6us-original-pipo-m6pro-m6-m8-adapter-power-charger-9v-25a-dc-25mm10mm-p-697.html
Tip = "9V 2.5A DC 2.5mm*10mm"
I see a couple I think might work, will others whom might have external battery packs please chime in if they think these will work or if you have alternative solutions.
I want as high mAh as I can get, and the ones I'm looking at are such as:
EasyAcc® 15000mAh External Battery Pack 5V / 12V (EasyAcc PB15000 PowerBank)
Anker® Astro Pro 14400mAh Multi-Voltage (5V 9V 12V) (Model - AK-79AN14K-BA)
This would be GREAT if it worked with these 9v Pipo tablets, 23000 mAh, and that's a lotta energy for it's size!
Charges via a standard wall plug OR SOLAR, and probably even with car adapter but not included it appears!!!
Originally posted by GPShunter View PostBut when it's working with my sim card in it's great and very accurate.
You seem like you're looking for extra power options, if so, want to stay in this loop with this until we find good solutions?Last edited by si3Dp7NXwLfb; 30 November 2013, 13:54.
Originally posted by si3Dp7NXwLfb View PostYou mean my like in my Pipo tablet? Near everything is from China nowadays, so I guess everything is not as stated then, correct?
There are currently 1452 users online. 0 members and 1452 guests.
