PMID701i (FULL ROOT)
    Never mind.
    If at first you don't succeed; call it version 1.0
      Originally posted by BLKHRT View Post
      Also instead of rooting the tablet for the android market(google play) Can i just download the apps on my pc and transfer it by usb connection or on the SD card.
      Hello!
      There's a plugin for Google Chrome that will allow you to do that.
      73 DE N4RPS
      Rob
        Noob here. Help pls.How do i root ?
        What do i have to press?Just ROOT and let it install?
        And after that do i have to press allow non market apps? to let me get apps not from the market?And after the root will i get paid apps for free?
          Download the file from the link in post #11. Extract it to a sd card.
          With the card in the tablet, navigate to the OneClick folder and click on the "SuperOneClick" application.
          For the Market Fix
          Originally posted by LiquidLimez View Post
          Here you go updated Market for proper redraw issue as well as modified for streaming and better touch response!!!
          This script also allows Netflix to work a bit better with streaming!!
          http://bedrockequipmentllc.com/android/Market Fix_LiquidLimez.rar
          It doesn't make the apps in the market free, it updates the Market app to the full market instead of the default restricted one.
          You can get non market apps by downloading them from the internet, or amazon. As far as getting paid apps for free, that may be possible if you search the internet for the apk. Download it and install it. I have some links to sites with free apk files, I will send them to you by PM.
            On youtube i saw some tutorials that show that it I don't need to put it on the sd card???
              then try it that way. Link me to the you tube video and I will check it out.
              I didn't remember but my son said we put it on the sd card. I know I did the market fix from the pc because I had to wait for the drivers to install for the tablet.
                Auf YouTube findest du die angesagtesten Videos und Tracks. Außerdem kannst du eigene Inhalte hochladen und mit Freunden oder gleich der ganzen Welt teilen.
                Can you give me the polaroid drivers i can't connect my pc to the tablet as well....
                  http://www.youtube.com/watch?v=PYIjY8JRlZY
                  the drivers are included in the Market Fix folder. View the read me file.
                  Mine installed part of the drivers and then I had to point it to the folder.
