Toshiba Thrive AT105 Tablet. What to do with it?
Hey all. I have a Toshiba Thrive AT105 Tablet sitting on the shelf doing nothing. I think its a good tablet because it has a full size HDMI, SD slot, and 2 real USB ports on board. Other than that, its just meh. It has Android 3.1 installed out of the box. I havent seen any ROMS on here to upgrade it. I am not sure what to do with it. I seached the forums here, and havent come up with anything. There is a Thrive forum, but it didnt give me any ideas either. Maybe I should use it as a media player for my RV. Any way I can flash this sucker into a new os? Anything else cool I can do with it? thanks.Tags: None
AW: Toshiba Thrive AT105 Tablet. What to do with it?
I have take a look to find a Tegra 2 Rom but i was not successful. Must take a deeper look when I came home.
Only one ROM will not be enough.
Because you need also Drivers for Touchscreen and other things inside.
Neomode
Take also a look here http://www.thriveforums.org/forum/to...e-development/
Neomode
Originally posted by neomode View PostTake also a look here http://www.thriveforums.org/forum/to...e-development/
Toshiba thrive
Originally posted by BradWorld View PostThat did the trick! Thanks. I browsed that Thrive Forum a bit and couldnt find the right threads. That led me right to what I needed. My Thrive has now been rooted and flashed and is now on Android 4.1.
Originally posted by playa19 View Post"What were the tools and downloads you used to root and flash your thrive? And how did it function?"
My Thrive has been working perfectly with the new rom installed. And it is much more usable now than when it had the original os installed.
There are currently 3321 users online. 0 members and 3321 guests.
