UPDATE: apparently with the ics build they moved /system from nandc to nandd which is why it wouldn't boot, someone please try the updated build now, it *DOES* work for the pmid701i now, this i can assure you. for the 701c i'm about 80% sure as i don't know the exact partition size on nandd on the default partitionmap, you may have to flash the onda rom first and then this?
PMID701i cwm-installable rom
Just finished uploading, i used the other stock-rom for the pmid701c as a template, so most of the credit goes to them, but i made the images.
UPDATE: apparently with the ics build they moved /system from nandc to nandd which is why it wouldn't boot, someone please try the updated build now, it *DOES* work for the pmid701i now, this i can assure you. for the 701c i'm about 80% sure as i don't know the exact partition size on nandd on the default partitionmap, you may have to flash the onda rom first and then this?Tags: None
Originally posted by shawnbusker View Post701c here, just tried this rom out on my tablet and so far it doesn't seem to work, so I'm not sure how you say it works for converting a 701c to a 701i. I looked at the images, boota.img is boot, but what is boot.img?
Shawn
Shawn
Originally posted by droblesa View PostOk, i cant seem to find the thread on how to install cwm. It should be a sticky. Can someone provide the link and instructions on how?
Originally posted by kaikunXP View PostJust finished uploading, i used the other stock-rom for the pmid701c as a template, so most of the credit goes to them, but i made the images.
UPDATE: uploading fixed rom now, apparently with the ics build they moved /system from nandc to nandd which means is why it wouldn't boot, someone please try the updated build now, it *DOES* work for the pmid701i now, this i can assure you. for the 701c i'm about 80% sure as i don't know the exact partition size on nandd on the default partitionmap, you may have to flash the onda rom first and then this?If at first you don't succeed; call it version 1.0
There are currently 2996 users online. 0 members and 2996 guests.
