K-R42 HDMI screen problem
    I have a K-R42 and it was working very good on my tv. One day i switched on the box and the color of the screen were red or pinky but you can stll see android running. When you switch the remote the screen will get black and come back after 2 seconds... The wierd thing is, that i can use the box through av cable but its not so cool to use
    I hooked the box to my samsung monitor which also has hdmi input. There everything is fine and works well. I also checkd my big tv with my notebook, it also works good with it....
    Could it maybe cause from an update which changed something with the hdmi software in the kernel ?
    I tried to flash many roms i have here but its all the same...
    Thanks for your help!
    Try a different HDMI cable.
      i used the same cable on a different lcd tv and it works... still thinking its something with hdmi software...
