So my particular setup is making it a pain to flash/setup this device. I have windows 8.1 on all my computers, so I can't flash this easily. I have to use a bootable usb drive, boot into lubuntu, run virtualbox to the saved image over my network and run windows 7 in order to try and flash finless. It seems like it works (there is a warning that 'erasing might stop at (6), mine does that) but it seems to work. However, when I plug it in and hook it up to my monitor (hdmi) I get no singnal (or it's not booting). I see two possible problems with my procedure:
1) I have to use this convoluted method to flash finless
2) I'm using a monitor rather than a TV
Again, I only have windows 8.1 on all my computers (except ubuntu on a server), and I don't have a TV in the house (just two monitors which support HDMI input). HOWEVER, with my flashing method I can restore the device back to stock using the manufactuer provided firmware (off geekbuying if I remember right).
Any idea what might be causing this? Any tips?
