The good news is, it does successfully change your build.prop identifiers and asks you to reboot.
The bad news is, I've tried to spoof my PMID701c with about 3 different high-end device and each change resulted in an infinite cycle between the blue "Internet Tablet" splash screen, and the shining Android logo (otherwise known as a bootloop) which I had to (easily) rescue with ADB by using the remount command to make /system RW, and then pushing through my backed up original build.prop
I will continue to experiment with this and try to find identifiers that do work for us, since recovering from the bootloop this causes is not a problem.
P.S if anyone else is stuck in this bootloop, do this (adb required of course):
1) While you see the boot loop cycling, plugin your tab to USB. You should hear the "new device" acknowledgement sound on your PC.
2)Pull up cmd, navigate to where you have adb working, and type this command:
adb shell mount -o rw,remount -t ext4 /dev/block/nandc /system
ADB will not confirm that it has done this, only go back to waiting for another command. This is OK.
3)Place your backed up build.prop in the same folder where you have adb.exe. If you did not back up your original build.prop. several of us PMID701 series users have posted ours and they should be usable by pasting it into notepad, and saving and naming the file as "build.prop"
4)Finally, input this command into your adb:
adb push build.prop /system
Unplug, and reboot. This boot will take longer than normal, but after a few minutes, you're back in business.
