MK908II, Green noise in 720P
    yesterday i received my two Tronsmart MK908II, in default screen mode 720P, there have always a green noise at center of setting panel (only) and this disapear when i switch in 1080p or 480p on my two device.Someone else have this issue?
    Bonjour! Je suis de Shawinigan, Québec, Canada
    I have find what is the cause of this issue, power supply again! I've changed this and it return to normal.
    my two device come with defect power supply, thank you Tronsmart!
    I'll check if the load current too low or too high that caused it.
