New screen for 701i :(
Originally posted by Fors78 View PostDoes anyone have any idea at all if it is possible to replace the screen/digitizer in the 701 models? My nephew dropped his and it cracked now touch wont work......
Cheaper to buy a new tablet to replace that one. Screens sometimes end up more expensive vs buying new tab..
Have not found one yet
Originally posted by LiquidLimez View PostCheaper to buy a new tablet to replace that one. Screens sometimes end up more expensive vs buying new tab..
Wish I was closer to you if you decide to replace. I had some hardware mods I wanted to try on the motherboard, but would be nice to have one that was broken to try them out on (upgrading the flash was the first thought).
If I had any budget left...
Originally posted by Fors78 View PostYeah I guess im out of luck lol. I don't think its possible to brick this tablet. But IF anyone does and wants to sell it....let me know.
I at least have some info,
Still couldnt tell you where to buy but I hae lots of numbers and a website, at least on my unit this is what I see (your results may vary as we seem to have a few diferent models around here)
The company is DPT-Group found here(I tried to bring it to the closest point to our guy as I could):
The numbers on the outside cable are 300-N3377B-A00 (trails under a sticker)
The barcode on the sticker is
dpt110054 d70n3377b-koc 2011215sz0939
Nice find Jim
Originally posted by jimwallcft View Post
Edit: oops, rechecked, the above is just the LCD screen, the dgitizer is also showing as 140 yuan. It is easy to spot since the resistive screens are 50 yuan
Yep that would be the digitizer
Originally posted by Fors78 View PostI think my LCD screen is ok, the tablet will turn on and everything still looks good, the touch just doesnt work. The glass on top is what is cracked. That is the digitizer? And is the digitizer what I linked?
If you doget one, the two parts are frequently glued together in one unit (not sure in our case). If so the best option is to use a hot air gun or hair blow dryer to heat up the surface to losen the glue, start with a lower setting since you dont want to take a chance at cracking the LCD's glass, and try to heat things up evenly again to try and keep from cracking the LCD.then use a couple small screwdrivers or even a plastic knife to try and slowly get them appart. It is delicate work, but not impossible either if you just take your time.
There are currently 3114 users online. 1 members and 3113 guests.
