problems with tv
problems with tv
Hi first post here. Don't know if any of you can help but here goes, I got my imito qx1 stick today in the post, flashed the new Rom and set up xbmc n all, done all this on the tv in the sitting room a Samsung tv, then brought into the bedroom to use there now, but the tv, a walker 32" led only bought two days ago, will not show it on either hdmi slot, in the info on the screen it says 1280x0 p, any suggestions ? Thanks in advanceTags: None
Originally posted by krusty411 View PostHi first post here. Don't know if any of you can help but here goes, I got my imito qx1 stick today in the post, flashed the new Rom and set up xbmc n all, done all this on the tv in the sitting room a Samsung tv, then brought into the bedroom to use there now, but the tv, a walker 32" led only bought two days ago, will not show it on either hdmi slot, in the info on the screen it says 1280x0 p, any suggestions ? Thanks in advance
Other than that i am not sure what would cause this to happen?
Originally posted by Silverback View PostShot in the dark here Krusty but when you set up the stick on the Sammy was it set to 1080p 60hz? Does the second tv fully support HD or is it HD Ready?
There are currently 2823 users online. 0 members and 2823 guests.
