there are not much options you will find. actually there are 3 options you got.
you can install those 3 options all with almost the same ways.
the first option is the original rom, it is based on android 4.1
it works, but there are wifi problems why Internet is slow, even sometimes the wifi doesn't jump on at all.
The second and the third option are custom made android roms.
you can choose CM 10.1 and AOKP 4.2 both based on an android 4.2.2 version.
with the CM 10.1 version you keep having wifi problems but they are less usual as in the original rom.
the AOKP version has no problems with wifi at all.
I found out that the best version for this mid class tablet is the AOKP version. It also runs XBMC quiet well.
