simple question, can any of you download files over 2gb from the internet?
Originally posted by amadorl608 View Posti cannot download any file over 2gb on the internet on my android tv box... and i have a 16gb micro sd card... anyway i can fix this... because on my android phone and tablets i can.
Can you can use an external hard drive for this?Last edited by Killerdude; 07 December 2013, 05:22.
Originally posted by Killerdude View PostYour SD card is probably FAT32, as that file system support files with max size of 2GB the only way is to cut the file in pieces by any archiever like 7zip or something. If this file is a movie file this will not work because you cannot play archieved files. The best way around this is to use a ext4 formatted disc.
or you can use an external hard drive this also works.To Infinity and Beyond.... XBMC
The card
There are currently 2778 users online. 0 members and 2778 guests.
