PIPO M9 Max - How To Set Lower Brightness?
Even on slowest brightness, the slider is on 20% and screen is still bright for me. If I try moving slider to the most left side, the brightness stays same and is not getting dimmer. I also think that is the reason my battery lasts less than it should normally. I did not update Android that my tablet came with but if I do, will it fix the brightness issue? Thanks. -
Try this https://play.google.com/store/apps/d....luxlite&hl=fr
I also had issues with my M9 (too high brightness, specially at night), and Lux helped me to reduce it...
Originally posted by Montezuma View PostTry this https://play.google.com/store/apps/d....luxlite&hl=fr
I also had issues with my M9 (too high brightness, specially at night), and Lux helped me to reduce it...Measy U4B (=Tronsmart T428) used by my kids!
Donate to Finless
There are currently 2248 users online. 1 members and 2247 guests.
