The bonus is that this ROM contains all of the new features I've added to RileyROM's since I did v1.1.
On first boot, you may notice that stock recovery will format all of the drive partitions before the system boots. That's the last you will see of stock recovery, because after first boot...CWM Recovery will automatically replace stock recovery. I'm not sure whether the touch screen will work with this tablet in CWM...if it doesn't let me know. If there are any external keys, you can use them to navigate the CWM screens.
Also, during the first boot process, if you have an external SD card inserted in the tablet, any apk file you have in a folder named "autoinstall" will automatically be installed during the first boot. Just rename the apk files to remove any spaces in the file names, or they won't install. Just open the app drawer and watch the apps populate as they are installed. Wait about a minute after the last app is installed to allow CWM to install before you reboot the tablet. Don't get too carried away with installing apps this way...I recommend only installing small utility apps. Key apps that unlock features in paid apps won't work this way, so don't waste time trying.
Other new features in the ROM kit include:
An updated First Time User's Guide.pdf file with all of the instructions and tips on installation. READ THIS BEFORE ATTEMPTING INSTALLATION OF THIS ROM!!!!! It will save you and me a bunch of time trying to explain things.
The new Rockchip Driver installation app is included in the ROM kit (just look in the folders). Use this first to install the drivers (if you haven't already done so in the past). Windows 8.1 is problematic with the installation of Rockchip Drivers, so maybe this app will help. There are threads all over Freaktab discussing Windows 8.1 (even in the Pipo section), so please read these threads before you get started.
Even though the drivers may be installed, you may have trouble rebooting your tablet from the flash tool. Because of this I also included the RKBatchTool in a folder called "alternate_reboot_to_flash_tool". Just run this app. If your tablet shows up as a pink box, press the "switch" button and it should put your tablet into flash mode. Use the ROM_Flash_Tool_137.exe to flash the ROM. Again READ THE FIRST TIME USER'S GUIDE!!!!!.
This ROM is:
Rooted
Debloated
English default, but all Android languages are available
Google Play Store fixes
Init.d Support added
Busybox commands added
Working CWM Recovery installed after first boot
Autoinstall feature from external SD (see above)
Boot Animation by Tattman65
Reboot app by Petrus
Download
If this ROM makes a difference for you, please consider a donation to support future RileyROM's here at Freaktab.com Donate!!!
