help adding external ant
    I have a geniatech ATV120 stick, and the wifi is REALLY bad, I mean I am at about 10 inches from the router and the connection sucks
    I was thinking on putting an externa antena see if that would help, but I need help finding where the antena is, any hardware experts could help me identify it?
    could this be it (circled in red)?
    Take the/A paperclip or antenna wire.. and hold it near the place you think it should go (red)
    Then look at the statusbar/wifi bars.. the should go Up.. if you are right
      yes! that is it! altho, I probably need a better antenna, it din't do much
