NHL Gamecenter Live
Originally posted by GreekSoldier View PostHi, does anyone have had success trying to stream live games with the NHL app? I have a MK808 and the same app works great, but with the X7 when I try to stream a game, it only shows me the NHL logo. I dont know why it isnt working.
Strauzo's Kitkat fixes NHL Gamecenter Live
Finally. Guys... Install Strauzo's 4.4.2. Kitkat. That works. Install gamecenter from market. Both ethernet and wifi work for me. None of the 4.2 roms worked. Wasser's 4.4.2 didn't fix the issue as well as this one. It can be quirky but works and quality is good at auto which i think is same as 1600 most of the time. I am still trying to find an xbmc that plays smooth 1080p though... Please let me know if you get it goin with this rom. 720p still rocks!! Strauzo kept me from takin this x7 back to the store!! I like this device again and have renewed positivity that it will only get better!
Reverting back to Wasser's Kitkat ROM
Originally posted by Mickster View PostFinally. Guys... Install Strauzo's 4.4.2. Kitkat. That works. Install gamecenter from market. Both ethernet and wifi work for me. None of the 4.2 roms worked. Wasser's 4.4.2 didn't fix the issue as well as this one. It can be quirky but works and quality is good at auto which i think is same as 1600 most of the time. I am still trying to find an xbmc that plays smooth 1080p though... Please let me know if you get it goin with this rom. 720p still rocks!! Strauzo kept me from takin this x7 back to the store!! I like this device again and have renewed positivity that it will only get better!
I will be re-flashing with Wasser's 4.4.2 and will test from there. I will use Beyond XBMC v3 and will also test the older Gamecenter App mentioned in this thread and let you know how it goes.
A little disappointed but whatever... I'm sure this will all get worked out in the long run....
Thanks to all the DEVS again for all the great ROMs anyway!!
Originally posted by Mickster View PostApparently Strauzo has been banned. Actually sounds like a total d*ckhead despite the fact that his ROM is the only one that seemed to make NHL Gamecenter Live work for me. Nonetheless... I don't trust that guy as he seems to be against the other great Devs on this site. Not sure I feel comfortable running his code on my device as he has been flagged as being dubious.
Here in Denmark we have a app called viaplay, make the same error as the gamecenter, could be Nice to find out why..
working NHL game center again
Originally posted by Phycopat View PostCant stop thinking about why is was working with his rom? Maybe some clever guy could take a look at his rom?
So here is my setup:
Wasser's 4.4.2 with 1080 kernel.
NHL game center from market. This time audio sync is way better than with strauzo's. Just slightly off but definitely tolerable and barely noticeable when watching game.
XBMC is Gotham nightly. Had to look for all new addons but this works best. Plays 720 and 1080 smooth. Only issue is that I can't use the seek bar to scan through a video. It will kick me out of the video. Worse with 1080 files but if I just play from start it works smooth and will run.
Hope this helps. Once again the x7 meets all my requirements. NHL, XBMC, Netflix, light browsing. I'm a happy camper!
Thanks Wasser and devs!!!
Originally posted by Mickster View PostWell perhaps I did something wrong the first time I installed wassers kitkat but now I reinstalled and have everything working even BETTER than before.
Originally posted by GreekSoldier View PostNice! Have you tried the old app with 4500 kbps, Kitkat is very smooth on x7 but I was having ton of freezes. I might give it another try because its very nice!
Lol!!
Sure I can try. Can u point me to the specific apk?
I can let u know how it goes... Thnx!
Originally posted by Mickster View PostI'm scared to change anything now that all is somewhat good!!!
Lol!!
Originally posted by GreekSoldier View Postoh ok lol well I tried it while I was on 4.4, quality was the best but you can't have the game info, you can just access live games but with better quality options. You can install both apps at the same time, the old one will be named Gamecenter. its the 3.0116 one that gives you the 3000 and over streaming option. How stable is your rom? I dont know why I had so much freezes on 4.4 lol
I'll see if I can find that old Gamecenter you mention to give it a try. I have never seen bit rate higher than 1600 on these android apps. On my PC in web browser I can up the value to 3000Kbps and in Carb0's Addon for XBMC (doesn't seem to work for 'live' games... only archived) there is an option for 4500 which actually looks pretty good but sometiems stutters (again for non-live games only).
NHL is a huge part of my time on these devices so I needed 'LIVE' games to work. 4.4.2 KitKat ROMS are the ONLY ones that I have seen that can pull it off (as quirky as they do) with the app. So far Wasser's ROM is the best (there is a message the pops up when I play the game 'you are not logged in at this time' but that can be ignored after clicking OK the video plays fine and there is minimal synch issue with audio but as I mentioned its very minimal and only noticed when you are watching people talk.)
The only real stability issues I have faced are with XBMC and that is because the nightly dev version (Gotham) is the only one I could get working with this ROM for smooth 1080 play back from XBMC addons (most ROMS were fine if I am playing a HD file from local source, ie. Memory stick, hard drive, etc.)
Hope this helps. I'll keep you posted with my results using older NHL app.
This latest set up I have is good and I'm pretty satisfied. You should try it out and let me know what issues you are facing... if any.
Originally posted by Mickster View PostIts pretty stable so far. (Then again I only re-flashed late Friday night) It only has options up to 1600Kbps. But I leave on 'AUTO' as it seems (in most cases) the same as 1600Kbps and doesn't ever go to that 'NHL logo screen' which is all I ever saw in the 4.2 ROMS with the exception of maybe one (I think Lewy's Rom... where you could hear the game and see the video 'seek bar' at bottom... but no game video. The odd time you could see it if you modified the bit rate but there was a lot of distortion in the picture with green blocks everywhere and then ultimately the NHL logo would pop up)
There are currently 1719 users online. 2 members and 1717 guests.
