I got a HMP8100 player from china, it works pretty good but the virtual button bar never auto-hides when i play any videos on the 3rd party player apps. i want it to play in real full-screen without the virtual button bar.
so i decided to root this device and modify the build.prop to get rid of the bar.
i downloaded the rom file in the link below and try to flash it with modified update.zip(build.prop) and re-signed it with google test key, but it seems not work. i think it uses a private key to do the verification.
i'm just wondering how to change the verification from it's private key to google test key or maybe the verification can be removed. but i can't find a way.
[device details]
# Philips HMP8100 official overview:
# i can't upload the stock rom file because it's too big, here is the direct link to the rom file in the philips official website:
[original uImage_recovery and more]
# the attachment zip files including the original:
factory_update_param.aml: factory_update_param.zip
u-boot.bin: u-boot.zip
uImage: uImage.zip
uImage_recovery: uImage_recovery.zip
# just without update.zip.
