Bluetooth tethering
    Bluetooth tethering
    I'm trying to get my Pipo M8HD tablet (RR 1.3) to access the internet via my phone. I'm currently typing this on a laptop tether to the phone so I know all is well and that it should work.
    I have turned on Bluetooth, paired with my phone and then ticked the box "Internet Access".
    All appears okay on both the phone and the tablet. The phone is showing 2 connections (Pipo + Laptop) and the Pipo has a Blue Icon in the top right hand notification area.
    For all this I can't get any internet access on the Pipo.
    Anything obvious I'm missing?
    Donate to Finless
    I have got the same problem
    here log with adb
    Code:
    I/BluetoothConnectionReceiver( 3370): onReceive(context, Intent { act=android.bluetooth.device.action.ACL_CONNECTED flg=0x8000010 cmp=com.google.android.googlequicksearchbox/com.google.android.search.core.service.BluetoothConnectionReceiver (has extras) }, 34:50:C3:65:D2:4C)
    D/        ( 1122): bta_pan_co_open:app_id:0, local_role:1, peer_role:4, handle:1
    D/        ( 1122): bta_pan_co_open:tap_fd:-1, open_count:0, conn->handle:1 should = handle:1, local_role:1, remote_role:4
    D/BTIF_PAN( 1122): btif_pan: btpan_tap_open(L403): in
    D/BTIF_PAN( 1122): btif_pan: tap_if_up(L348): found mac address for interface:bt-pan = 8a:37:09:09:75:a1
    D/BTIF_PAN( 1122): btif_pan: tap_if_up(L353): setting bt address for interface:bt-pan = 45:25:73:48:b1:85
    E/BTIF_PAN( 1122): btif_pan: ## ERROR : tap_if_up(L358): Could not set bt address for interface:bt-pan, errno:Cannot assign requested address##
    E/BTIF_PAN( 1122): btif_pan: ## ERROR : btpan_tap_open(L434): can not bring up tap interface:bt-pan##
    I have resolved this by changing the MAC adress in a file
    This address is set by boot.img in file init.rk30board.rc
    # permissions for bluetooth.
    mkdir /data/misc/bluetoothd 0775 bluetooth bluetooth
    setprop ro.bt.bdaddr_path "/data/misc/bluetoothd/bt_addr"
    chown bluetooth bluetooth ro.bt.bdaddr_path
    So I change this address in the file /data/misc/bluetoothd/bt_addr
    From 45:25:73:48:b1:85 to 00:25:73:48:b1:85 : and for me it's OK
      Ok. My Address was set to 0D:xx:xx:xx:xx:xx in the file. I'm trying 00:xx etc but can't seem to persuade ES3 Explorer to edit. I've got root explorer on and / set to R/W but it still won't play
      I checked the code (Git Hub) and I can see the problem is created by trying to assign the MAC address in "ioctl(sk, SIOCSIFHWADDR,(caddr_t)&ifr)" but I can't see why without debug on.
      Donate to Finless
        Strange i used es explorer or Root explorer without any problem
          I changed to 00:xx:xx:xx:xx:xx but still no internet.
          If you delete bt_addr then one gets auto-generated and it STILL doesn't work
          Donate to Finless
            Can you make an adb logcat to see if it is the same problem?
              I can't install stuff on this laptop (works), so it'll have to wait until the weekend. Unless there is a way to get diagnostics directly on the tablet?
              Donate to Finless
                I use this: https://play.google.com/store/apps/d...d=com.bluexvpn to get internet on my tablet via bluetooth tethering.
                It works, but I need to load tun.ko module at every boot: https://play.google.com/store/apps/d....tun.installer
                  Eh ! Yes good point
                  I totally forget this point because I always add this in my ROM.
                  The ROM M8HD 1.3 by Riley, add the tun module but there are not loaded in the boot img !
                  So you need a init.d file to load them at boot like I said here in the finless rom for M9 Pro
                  Sorry Darrellr !
                    Now this is strange. I just tried to insmod and it already exists!
                    Lsmod confirms tun loaded
                    Install blue VPN and .... Nothing aaaarrrrggghh
                    Sent from my M8HD using Tapatalk
                    Donate to Finless
                      Maybe we need to find a different tun.ko file. It worked in earlier ROMs.
                      Sent from my SAMSUNG-SGH-I537 using Tapatalk
                      Randy
                        I'm using your last one on M8HD v1.3 and it's working well
                        just load also the file tcp_veno.ko , don't know if it really matters !
