I had android sdk already installed so you need the adb driver to make this work. Also my tab does not have "busybox" as described below.
I installed the program, then plugged in the tablet with USB debugging and virtual location enabled. Program "saw" the device and connected to it with a dual window graphic file list like the old file commander program that allows a lot of features through the computer.
Am copying complete root directory to my pc now.
Features
Files Explorer
- copy multiple files/dirs between Device and PC
- copy multiple files/dirs between Device folders
- delete multiple files/dirs from Device
- drag&drop multiple files/dirs in to progrm
- drag&drop files/dirs between program tabs
- files/dirs properties
- edit files/dir permissions
- bookmarks
- new dir and rename options
Applications Manager
- batch/single apps install
- install as private
- install as update
- install as system app
- batch/single uinstall apps
- uninstall system apps
- uninstall and keep app data
- batch/single apps backup to any dir on Device/PC
- app details
- search app on Web Android Market/AppBrain/AndroLib/Cyrket
- windows integration
Search Bar
- search apps in device Android Market
- search location on device Google Maps
- open URL in device browser
Device Info
- device
- ROM
- partitions
- battery
Console
- run any shell command
- run sh script from PC
Logcat
- messages coloring
- message type filter
Flashing Tool
- flash any zip update/ROM/mod from PC
- flash recovery/boot/system/userdata/cache image from PC
Virtual Input
- emulate device keys
- send text to device text field
Signing Tool
- sign any zip file
- sign any apk file
- program explorer integration
Other
- reboot, reboot to recovery, reboot to bootloader, power off device
- multi device support
- WiFi Mode
- No Device Mode
- screenshots (beta)
Requirements
Phone Requirements:
- ADB ROOT Access
- BusyBox
- „Settings->Applications->Development->USB debugging” must be enabled
- USB Cable
Computer Requirements:
- Windows XP/Vista/7
- ADB USB Driver
- Java JDK
- Minimum 800×600 screen resolution
