Measy RC12 not working on MK908II
    Hi there,
    The RC12 works on my laptop and PC but not on the MK908II, if I connect a USB mouse to the MK908II it works perfectly. I've already reset it. Any idea on anything else I can do?
    Actually using RKRemoteControlGeneralCastV2.0.2 as a work around.
    Many thanks in advance
    Originally posted by spaniard View Post
    Hi there,
    Not sure why it would not work, I have one and it works fine on the MK908. I do not have MK908II model so cannot test. Are you putting the receiver in the USB or the OTG port?
      In the OTG, also tested in the USB
        El problema no es del mk908II, por lo que te puedo decir, yo tengo el mismo air mouse y va perfecto en la stock rom y en la finless 1.5a. Prueba a conectar el rc12 en el pc por si no funcionase yo lo he conectado a un pc con windows 8 y tambien va.
          search for one of my thread, it have surely a solution. put the missing keyboard layout file.....
          sorry i'm not at home....
            No se sincronizan el mk 908 y el Measy rc12
            The same thing happens to me. They work independently well, each of them. The smart tv in any Tv, and the wireless keyboard in any PC, but not togheter. They do not synchronize each other.
            The pointer does not appears on screen and keyboard is dead
            Can You solve it ?
            A mi me pasa lo mismo. Funcionan bien independientemente cada uno de ellos. El smart tv en cualquier Tv, y el inalambrico en cualquier Pc, pero no los dos. No aparece el puntero y no se sincronizan sabes como solucionarlo?
            Gracias.
            Hi there,
              Can You solve it ?
              Gracias.
              http://www.freaktab.com/attachment.p...6&d=1370914684 put it in system/user/keylayout set permissions as rw-r--r-- same as the others files in directory and reboot or it will not work.
              keep in mind that any keylayout file from manufacturer or custom one specific device only re-map the generic keylayout to have like in this case a working measy rc12. the mapping included in any stock android rom or modded rom have the same keymap as a base for android on-screen keyboard.
              only a few branded android device with a rom specific could have is own keyboard mapping but is pretty pretty rare due that user could only use remote or keyboard sold with this device or from this brand... in other word, don't broke the remote control or know how to mess around with remaping if layout file are not hardcoded..
                No se sincronizan el mk 908 y el Measy rc12 / Measy RC12 and MK908II don't work togheter
                Good Morning Malfrat.
                Your solution seems not easy to me, but I will try to do it. Thank You very much Malfrat
