Quick and Easy Root for ematic EGQ307 series
    Quick and Easy Root for the ematic EGQ307 series Allwinner QuadCore-A31 Bean4.2 Tablet
    This file will install the su binary and set correct permissions only.
    1. Download and copy attached RootFromOTA.zip to external sdcard
    2. Insert sdcard and goto Settings -> Backup & reset and select Recovery Mode
    3. Select apply update from external storage and select RootFromOTA.zip
    4. Reboot
    5. Install SuperSU from play store
    6. Enjoy Root
    help
    4. Reboot
    6. Enjoy Root
    I have a egq307bl i need the orginal wpa_supplicant plz can someone upload it plz
      What folder is this file in?
        thanks
        system/bin thats the wpa_supplicant
        could you also upload the wpa_supplicant.conf
        thats in system/ect/wifi call wpa_supplicant.conf
        plz i need my tablet back to wifi and i messed it up i backed it up but i deleted the backup folder by accident .
        thank you if you could upload it
        i tried many differt ones none works so i guess its got to be from the same tablet
          help
          anyone dont think u need root to copy the files to a sd card and upload plz anyone?
            Is this also quick and easy to undo the root and make it factory reset in case I need to return it for warranty?
              Why do you need these files? Is it because you tried to do this root and the tablet broke? I have the BL tablet too, so I would like to know.
                Has anyone tried this yet?
                  Yes, this root method works well and easy too.
                    Need Stock Rom
                    Don't know if anybody still has this tablet but I'm desperate. I soft bricked this thing and now I need a copy of the stock Rom. Can someone please upload a copy?
                      Thank you ssyspro
                      Ssyspro.......You are a godsend. Your file worked like a charm.
                      I spent ALL night trying to get ADB working with my girlfriend's Ematic tablet and I had no luck. I tried editing the Google driver, universal drivers, and even a program called Imactor that is supposed to create a driver for you. Nothing worked. Everything installed the tablet but ADB would not recognize it. I found your thread and in 5 min I had root access. Thank you!!!
                        Backup before Root?
                        Any way to back this thing up before rooting? After trying every ADB driver out there and looking at every webpage I could find, as S_O_B indicated, it looks like it's just not possible to get the ADB interface working on this thing (or a least to get ADB to recognize it's connected). I'd really like to be able to restore this thing to default if needed. It'd be nice to have an app that would create an image on the SD card similar to the root file.
                        Thanks,
                        Beo
                          Which "SuperSU" are you referring to. Today's search in the Google Play Store shows 5 or 6 with that name. One costs $2.49. If that's the paid version of the free one you mean, I'm glad to pay the guy for development work.
                            You can use any SU app (SuperSU, Superuser) free or paid the app just allows you to update the su binary and grant or manage superuser rights. If you don't want to have control over what apps are using superuser rights then you dont need to install the app at all.
                              Thread Closed
                              I am closing this thread because I no longer have any of these tablets, I purchased them for my kids and they have broken the lcd screens on all of them.
