problem flashing 4.2.2
    Hi all,
    i can't flash the new Fw.. and also the old ones....
    here the log...
    Someone can help me ???
    16:28:50 453Rockchip Batch Tool v1.7.1.1 start run
    16:29:47 921**********Restore Start Total<1>**********
    16:29:47 921<Layer 6-1> Test Device Start
    16:29:47 921<Layer 6-1> Test Device Success
    16:29:47 921<Layer 6-1> Lowerformat Device Start
    16:30:13 937<Layer 6-1> Lowerformat Device Success
    16:30:13 937<Layer 6-1> Test Device Start
    16:30:13 937<Layer 6-1> Test Device Success
    16:30:14 015<Layer 6-1> Check Chip Start
    16:30:14 015<Layer 6-1> Check Chip Success
    16:30:14 015<Layer 6-1> Get FlashInfo Start
    16:30:14 015<LAYER 6-1> INFO:FlashInfo: 0 0 0 1 0 10 10 28 1E 2 5
    16:30:14 015<Layer 6-1> Get FlashInfo Success
    16:30:14 015<Layer 6-1> Prepare IDB Start
    16:30:14 015<LAYER 6-1> INFO:CS(1)(8192MB)(HYNIX)
    16:30:14 015<LAYER 6-1> INFO:CS(3)(8192MB)(HYNIX)
    16:30:14 031<Layer 6-1> Prepare IDB Success
    16:30:14 031<Layer 6-1> Download IDB Start
    16:30:41 765<Layer 6-1> Download IDB Success
    16:30:41 765<Layer 6-1> Reset Device Start
    16:30:42 781<Layer 6-1> Reset Device Success
    16:30:42 781<Layer 6-1> Wait For Loader Start
    16:30:44 171<Layer 6-1> Wait For Loader Success
    16:30:44 171<Layer 6-1> Test Device Start
    16:30:44 171<Layer 6-1> Test Device Success
    16:30:44 171<Layer 6-1> Download Firmware Start
    16:30:44 203Error:RKU_Write-->WriteFile failed,bRet=1,err=0,size=49152,write=16384
    16:30:46 421Error:RKU_ClearBuffer-->totalRead=0
    16:30:46 421Error:RKU_Write-->WriteFile failed,bRet=1,err=0,size=49152,write=16384
    16:30:48 640Error:RKU_ClearBuffer-->totalRead=0
    16:30:48 640<LAYER 6-1> ERROR:RKA_File_Download-->RKU_WriteLBA failed,Written(0),RetCode(-3)
    16:30:48 640<LAYER 6-1> ERRORownloadImage-->RKA_File_Download failed(misc)
    16:30:48 640<Layer 6-1> Download Firmware Fail
    16:30:48 640**********Restore Done Success<0> Fail<1> Time<60718>ms**********
    same issue here after accidentally hitting upgrade instead of restore on rkbatchtool while trying to flash the newest firmware 006. :'(
    turns out it was a bad unzip or download because I redl the fw and it flashed fine, whew!
