When do you guys think we will start using cwm More?
By when will we start using cwm more, i mean for flashing roms n what not. I know were using the otg port for this and it works great. But its kinda the like this on samsung, it has odin n that works great but with that said i still would prefer cwm as my primary flash installer and odin/otg port as my backup plan. Just wondering n thanksTags: None
Leolas has just released his Neo X7 quick shot ROM with the Nitro team. This ROM includes CWM recovery. I suspect this could be extracted and flashed into any of the X7 ROMs.
Once you have CWM it should be pretty easy to make up flash kits by adding any new ROMs kernel, boot and system images to an update template. The only thing that would cause issues is if the ROM uses incompatible parameter sizes.900Supersport
freaktab developer
sorry duplicate900Supersport
freaktab developer
Re: When do you guys think we will start using cwm More?
From cwm you can't change partitions size, but if your partitions fit, you can install roms using a zip tempate I did and posted in rk3188 secction I think (I am from my mobile and I cant search the precise link) and I made cwm recovery for a lot of devices (thanks to fun, he made the recovery binary). So if you want you can do it.
leolas.REMEMBER, YOUR FEEDBACK IS VERY IMPORTANT TO US.My devices:
There are currently 2545 users online. 1 members and 2544 guests.
