Edit AndroidManifest.xml in XBMC
    Anyone now a way to edit the AndroidManifest.xml in xbmc to make it a act as launcher????
    It is possible but you will have to install a couple of programs in windows to open up the apk, write a couple of lines there, run the program again to make the apk and run the 2nd program to finish it up. There are some guides online for it. If you cannot find it tell me and I'll send you the link later. I did exactly this for the SPMC xbmc version but the one on this site is better. I'll probably do it to the second beta of the minix xbmc so I get the mpeg2 he acceleration. Maybe
    Edit:
    Why tomorrow if it can be done today? Here it is:
    Here it explains the programs to download and what to do...
    Read this also:
    How to Write Custom Launcher App in Android In Android the screen that appears when the phone starts is called “Launcher Screen”. It is …
    Basically what you should put in the AndroidManifest.xml file is between </intent-filter>
    Good luck and enjoy
